JW
Joe Weinpert
Sun, Sep 28, 2025 9:19 PM
I'm encountering an issue while using Turtle3D to create a handle. The code
consists of two modules: a standard module and a bending module.
The standard module functions as expected, but the bending module does not
produce the desired results. I anticipated that the handle would turn left,
then right, while remaining perpendicular to the z-axis, ultimately lying
flat on the starting plane. However, this is not happening.
The only difference between the two modules is the addition of "left" and
"right" movements to the "up" arcs in the bending module. What could I be
missing?
Joe Weinpert
include <BOSL2/turtle3d.scad>
$fn = 64;
handle();
handleBend();
module handle(){
path = turtle3d([
"move",1,
["arc",2,"up",36,"shrink",[1,2]],
"arcdown",2,72,
["arc",2,"up",36,"grow",[1,2]],
"move",1
state=move([0,.75,.375]),
transforms=true
sweep(
ellipse( d=[.75,1.5] ),
path
module handleBend(){
path = turtle3d([
"move",1,
["arc",2,"up",36,"left",45,"shrink",[1,2]],
"arcdown",2,72,
["arc",2,"up",36,"right",45,"grow",[1,2]],
"move",1
transforms=true
sweep(
path
missing?
Joe Weinpert
$fn = 64;
handle();
handleBend();
module handle(){
path = turtle3d([
"move",1,
"arcdown",2,72,
"move",1
transforms=true
sweep(
path
path = turtle3d([
"move",1,
"arcdown",2,72,
"move",1
transforms=true
sweep(
path
Sun, Sep 28, 2025 10:14 PM
I think the problem is that when you apply rotations it also spins the
reference frame, so the direction that is "up" or "left" is not where you
think it is. This is really hard to deal with. I added absolute rotations
to try to provide a tool for working around this. You could also try
"rollto" to force the reference frame back into an orientation you
understand. I have basically no experience actually using turtle3d so I
don't have any deeper insights.
On Sun, Sep 28, 2025 at 5:20 PM Joe Weinpert via Discuss <
code consists of two modules: a standard module and a bending module.
missing?
Joe Weinpert
$fn = 64;
handle();
handleBend();
module handle(){
path = turtle3d([
"move",1,
"arcdown",2,72,
"move",1
transforms=true
sweep(
path
path = turtle3d([
"move",1,
"arcdown",2,72,
"move",1
transforms=true
sweep(
path
> missing?
> Joe Weinpert
> include <BOSL2/std.scad>
> $fn = 64;
> handle();
> handleBend();
> module handle(){
> path = turtle3d([
> "move",1,
> "arcdown",2,72,
> "move",1
> transforms=true
> sweep(
> path
> path = turtle3d([
> "move",1,
> "arcdown",2,72,
> "move",1
> transforms=true
> sweep(
> path
JW
Joe Weinpert
Mon, Sep 29, 2025 1:09 PM
Thanks. Wish there was a way to determine how much the reference frame is
being spun when combining things like "up" and "left".
I was looking at all the "rollto" sub-commands but still can't figure out
how to use them (there are no examples).
Am trying the "arctodir" next to get the frame reference back.
Joe Weinpert
www.jwstudio.art http://jwstudio.art
On Sun, Sep 28, 2025 at 6:14 PM Adrian Mariano via Discuss <
not produce the desired results. I anticipated that the handle would turn
left, then right, while remaining perpendicular to the z-axis, ultimately
lying flat on the starting plane. However, this is not happening.
missing?
Joe Weinpert
$fn = 64;
handle();
handleBend();
module handle(){
path = turtle3d([
"move",1,
"arcdown",2,72,
"move",1
transforms=true
sweep(
path
path = turtle3d([
"move",1,
"arcdown",2,72,
"move",1
transforms=true
sweep(
path
Joe Weinpert
www.jwstudio.art <http://jwstudio.art>
>> missing?
>> Joe Weinpert
>> $fn = 64;
>> handle();
>> handleBend();
>> module handle(){
>> path = turtle3d([
>> "move",1,
>> "arcdown",2,72,
>> "move",1
>> transforms=true
>> sweep(
>> path
>> path = turtle3d([
>> "move",1,
>> "arcdown",2,72,
>> "move",1
>> transforms=true
>> sweep(
>> path
